Hello From the DC Area
dk-info
Post by dk-info »
I am a newbie working in Arlington VA. I Inherited an original Rostock Max V1 that is not in operation. I am interested in getting it up and running, updating it to a V2 if possible. I look forward to the conversation.
Re: Hello From the DC Area
Post by Xenocrates »
Welcome to the forums. I hope you get it back into operations, and that your conversion goes smoothly. Let us know if you run into any trouble with it.
Welcome to the forum! You probably have not downloaded the V1 manual for assembly so I will point you to it..
http://download.seemecnc.com/rostockmax ... -Guide.pdf
This manual should guide you to reassembly on your version 1 machine plus please ask us questions when you feel the need
just make sure you always tell us that you are using a version one and what upgrades etc you are using.
SeeMeCNC do make a conversion kit that converts your version one to a version two....http://www.seemecnc.com/collections/par ... =818774673
I see the kit is out of stock but you can contact them and see when the kit should be made available and that you need one (Black or White).
