PID Autotune Temp Too High (Rostock MAX v2) (SOLVED)
Aureus
Post by Aureus »
Hello all,
So I am doing the command for the PID Autotune (M303 S200) and I got the "Temp too high" error (On my Orangesicle Printer), so I toned the Extr.1 PID Drive Max to 128 like the guide said to do, I re-entered the code and I got the "Temp too high" error AGAIN! After shutting the printer down, turning it back on, disconnecting MatterControl and doing all I could, the problem is not fixed. If anyone could help me that would be fabulous!
Any help greatly appreciated!
-Aureus
My Printers:
Orangesicle (Rostock MAX v2)
Re: PID Autorun Temp Too High (Rostock MAX v2)
Post by Xenocrates »
What is the maximum temperature you have set for your extruder? should be an EEPROM entry for that. What temperature does it reach while auto-tuning?
If it's drastically overshooting, try tuning to the temperature you want, minus the overshoot, and then after that adjustment is made, tune to your desired temperature. Or decrease P/increase D before tuning.
Aureus
Post by Aureus »
SOLVED
So, what I did to solve was as follows: I went to the EEPROM Configuration and edited the Extr.1 PID Max Value and I put that to 128, then I ran the PID Autotune and it worked!! After the PID Autotune worked, I went back to the EEPROM and changed the Extr.1 PID Max Value to 238. Hope this works for anyone who has this problem!!
-Aureus
My Printers:
