Can't figure out what is causing this warping. The piece on the right is warped the one on the left is how it should look. Any ideas?
[img]http://imagizer.imageshack.us/v2/1024x7 ... 8Rio8e.jpg[/img]
Using custom Rostock and Simplify3d
						weird warping
Re: weird warping
http://imagizer.imageshack.us/v2/1024x7 ... 8Rio8e.jpg Is the image.  I think it's an odd bit of layer shifting, but it's hard to tell.  Have you changed much between the two parts?
Re: weird warping
Xenocrates, I can't get your image to open either.
				DarthBeavis
- Noob
Re: weird warping
two different printersXenocrates wrote:http://imagizer.imageshack.us/v2/1024x7 ... 8Rio8e.jpg Is the image. I think it's an odd bit of layer shifting, but it's hard to tell. Have you changed much between the two parts?
Re: weird warping
That's really interesting.  Are you using the same G code for them both?  Would it be possible to use the same G code (is the nozzle size and so on close enough for that to work)?  Do you see this on any other parts?
It looks like it might be resonance in the drive system or a slicing bug almost, since it's so regular. Have you checked the mechanics and if your hotend holder is loose?
				magicmushroom666
- Prints-a-lot
Re: weird warping
Did the code come from Slic3r? There's a bug in the latest version that causes thin walls to bulge like that...
https://github.com/alexrj/Slic3r/issues/2960
