IMBoring25 wrote:With the thin spots being consistently on the clockwise side of each tower, it would seem to me that would be consistent with a whole build that's twisted as it goes up, so there's a consistent circumferential lean on each tower.
I'm not sure if the effect of a frame twist would be so dramatic. I have a theory that this is caused by backlash in the belt system. The farther out to the edge near a tower the effector is, the more the positioning depends a lot on that one tower. As the effector passes a tower, the tower has to move rapidly up, then rapidly down. As it is moving up, it's taking up some of the lash, so the effector is lower than it should be (because some of the upward movement was wasted on backlash), conversely, once the effector starts moving past the tower, the carriage is dropping, and thus the backlash comes into play again. the carriage needs to be forcing the effector down, but the lash prevents it from pulling down as far as needed.
So, in essence, the belt tension might be a factor... do you have astrosyn dampers on?
