jdurand wrote:Simple math tells you why you don't run a 24V heater through the Rambo. The bed is about 1 ohm, therefore:
At 12V the bed draws 12 Amps which is right at the 80% point of the 15A fuse. You don't want to exceed 80% long term because fuses have a +/- tolerance and they also age (they will blow sooner when they get older...ask the guys who designed the Solar Max satellite).
At 24V the bed draws 24 Amps which is way over the fuse level.
Just for info, a Wattage comparison:
At 12V the bed is drawing 144 Watts.
At 24V it's drawing 576 Watts (about half what a small burner on an electric cooktop uses).
Math used:
Amps = Volts / Resistance
Watts = Volts * Amps
Watts also = Amps * Amps * Resistance
Watts also = Volts * Volts / Resistance
R3 bed is actually a bit higher resistance which is why they are selling it as 24V only. Apparently they are more like 1.2ohm, so 20A and 480W at 24V. The PSU is also voltage adjustable from 22V-26.4V, so I plan on turning the voltage down to its lower limit of 22V...making the bed see 18.3A and 403W.
The only think I'm unsure of about this is whether or not a 24V-12V buck converter will cut the voltage in half on make the output 11V or if it is specifically targeting 12V whether the input is 22V or 24V. Maybe someone with a bit more knowledge of voltage converters can comment.
