http://www.projectorcentral.com/Optoma-HD141X.htm
It says it was released past month...
In Spain you can get online it for less than 600eur: http://allshop.es/es/videoproyectores-3 ... 49608.html
Any brave one to try it?
No kidding?? Sounds too good to be true, but I trust you.guanu wrote:if you are looking for a 1080p projector cheap, I would suggest looking into the Acer P1500.... its a 1920x1080 native projector, and requires NO modification to use on a resin printer, so you can use it as a normal projector without having to "un mod" anything.. no opening at all, just focus and go!
Guanu
Good to know, and it is an affordable one too!guanu wrote:if you are looking for a 1080p projector cheap, I would suggest looking into the Acer P1500.... its a 1920x1080 native projector, and requires NO modification to use on a resin printer, so you can use it as a normal projector without having to "un mod" anything.. no opening at all, just focus and go!
Guanu
