Need something cool to print
Well im looking for something cool to print. Something the wife would like as well would be a big plus. Gotta keep her happy too.
Lost pla castings? see me
Re: Need something cool to print
Here's something I threw together tonight, A twisted Savonius turbine. about 8 inches in diameter by 12 inches high. All you need to finish it is a pair of 3/8x 1/4 flanged bearings, a piece of 1/4" all thread rod, a belleville washer, or something conical for the bottom bearing to set on,, a couple of nuts, a coupler, and an eyebolt to hang it from. I'm currently printing it in abs,,,,, I hope.
- full twist cap.zip
- (288.49 KiB) Downloaded 277 times
- full twist.zip
- (2.94 MiB) Downloaded 258 times
Thats pretty cool and I think the wife would like it too. Hmm now the evil genious in me wants to couple it to a generator...LOL
- nitewatchman
Cool, be sure to post a photo!
- barry99705
How did it go?
Pictures please
Pictures please
If you look at my live view cam, you can see it currently stuck to the bed, I'll be printing the cap when I get home from work tonight.
It wants flash and that makes my computer crash.
Well, when it's finished, I'll be sure to post a picture. Meanwhile, I went a little heavy on the layers, and burned through a spool of PLA, Now I get to see how much of a mess changing up from PLA to ABS during a print.
And ABS doesn't stick to PLA. The single layer of PLA just peeled right off.
In the middle is the print from the file I posted. It was printed heavy with PLA, damn near the whole spool. Printed with the .7 nozzle, .5 layer height, and .75 layer width. 4 layers for the perimeter, and it took 11 hours to print the main body. The cap was only 2 hours, ran out of PLA (YAY!!) during the first layer, and finished it with ABS. Because of all the stringing between the two vanes, i sanded and painted it green. The small blue turbine to right was my first turbine, printed in sections, and the larger one on the left was my second, sectional turbine. I will print another one piece turbine out of ABS, only this time it will be light weight. The two large models were created with the intention of using 3/8"x1/4" flanged bearings, but the green one was so heavy, I found, and used a 5/8"x1/4" flanged bearing instead at the bottom.
