Hello everybody Jack here!
Proud owner of an Orion Delta and hopefully a Rostock Max V2 at some point.
Upload regular time lapses on YouTube of builds : http://youtu.be/BrpLPVtNaY4
Owned the Orion for around 3 months and have over 23 days of run time.
Good day from the UK!
Re: Good day from the UK!
Thanks for sharing, nice print by the way. Is that ABS or PLA? You may have better luck getting parts to stick to the glass plate with an Elmers glue stick or Aqua Net hairspray.
JJ
JackFoz, if you haven't been welcomed to the forum, I would like to do that now.
Please be an active member and help to answer user's questions or ask questions and
we will do our best to answer them.
Happy printing!
Happy printing!
Thanks for the welcome!jjjohnson wrote:Thanks for sharing, nice print by the way. Is that ABS or PLA? You may have better luck getting parts to stick to the glass plate with an Elmers glue stick or Aqua Net hairspray.
That was PLA and it is indeed a beautiful print. The failures with the jaw were caused first by bad design and the raft failed due to the masking tape overlapping and causing a high spot.
