Sculptris by Pixologic
http://pixologic.com/sculptris/
PartDaddy
Post by PartDaddy »
I was searching for sculpting software recently and found Sculptris. The software is here: http://pixologic.com/sculptris/
Very intuitive and fun. To print something you create, export the .OBJ file, then open the .OBJ using Slic3r. After scaling and orienting, you can export the .STL. Finally, open the .STL in Repetier and process as usual.
~PartDaddy
SeeMeCNC Owner & Founder
Since 1996
Island3
Re: Sculptris by Pixologic
Post by Island3 »
Heyyyyy this is very cool!! It's perfect for us visual folks.
LorenOlepi
Post by LorenOlepi »
Yeah this software is awesome... use it to touch up/modify my 3d Scans ;)
Print_This
Post by Print_This »
very cool, i actually used it export it, and import into autodesk print utility and it repaired it and then just exported out as stl from there. have to spend more time on it! :)
If you survive chicago winters you can survive 3d printing!
Return to “Sculptris”
