Just place these in the controls section of config.yaml.
Bed Calibration:
- children:
  - commands:
    - G28
    - G0 Z%(height)s F1500
    input:
    - default: 5
      parameter: height
    type: parametric_commands
  - commands:
    - G28
    - G0 X0 Y90 Z%(height)s F1500
    input:
    - default: 5
      name: G0 X0 Y90 Z
      parameter: height
    name: Zero Z axis
  - commands:
    - G28
    - G0 X77.94 Y-45 Z%(height)s F1500
    input:
    - default: 5
      name: G0 X77.94 Y-45 Z
      parameter: height
    name: Zero Y Axis
  - commands:
    - G28
    - G0 X-77.94 Y-45 Z%(height)s F1500
    input:
    - default: 5
      name: G0 X-77.94 Y-45 Z
      parameter: height
    name: Zero X Axis
  type: section
Basically, enter a value into the box and it will lower the nozzle to that height at which ever calibration point you want. From there use the LCD to lower it step by step.
EEPROM Updater
- children:
  - commands:
    - M206 T3 P145 X%(maxLength)s
    - M206 T3 P149 X%(maxLength)s
    - M206 T3 P153 X%(maxLength)s
    - M500
    - G28
    input:
    - default: null
      name: Max Z height
      parameter: maxLength
    name: Set XYZ max length
  - commands:
    - M206 T%(type)s P%(location)s X%(value)s
    - M500
    - G28
    input:
    - default: null
      parameter: type
    - defualt: null
      parameter: location
    - default: null
      parameter: value
  - commands:
    - M206 T3 P218 X%(pgain)s
    - M206 T3 P222 X%(igain)s
    - M206 T3 P226 X%(dgain)s
    - M500
    input:
    - default: null
      parameter: pgain
    - default: null
      parameter: igain
    - default: null
      parameter: dgain
  type: section
- children:
  - command: M114
    regex: X:([0-9.-]+) Y:([0-9.-]+) Z:([0-9.-]+) E:([0-9.-]+)
    template: 'Position: X={0}, Y={1}, Z={2}, E={3}'
    type: feedback_command
  - command: M503
    type: command
  - name: Z Height
    regex: EPR:([0-9.-]+) ([0-9.-]+) ([0-9.-]+) X max length
    template: ' {2} |Type: {1}  | Location: {0}'
    type: feedback
  - command: M503
    regex: EPR:([0-9.-]+) ([0-9.-]+) ([0-9.-]+) Extr.1 PID P-gain
    type: feedback
  - command: M503
    regex: EPR:([0-9.-]+) ([0-9.-]+) ([0-9.-]+) Extr.1 PID I-gain
    type: feedback
  - command: M503
    regex: EPR:([0-9.-]+) ([0-9.-]+) ([0-9.-]+) Extr.1 PID D-gain
    template: '{2}  |Type: {1}  | Location: {0}'
    type: feedback
  - name: Printer Radius
    regex: EPR:([0-9.-]+) ([0-9.-]+) ([0-9.-]+) Horizontal radius
    type: feedback
  type: section
