Hello from Ontario.
Looking forward to printing up a storm (like the weather outside) once my Orion shows up. It has been help up at customs for the last 6 days and may be for another 2weeks. Anyone ordering should probably use UPS, they provide an agent service.. I went with USPS as a suggestion from the manufactures but they just hand it over Canada post so it probably will be 2 weeks. Boo. Anyway, I've been reading the forum and have learned a lot already.
Hello
Hello
Re: Hello
Hello Holy1! Welcome to the Forum! You will be very happy with the Orion and we as a community are quite proud to be owners of the finest
printers available anywhere. In our documentations section you will find some manuals and such for the Orion and I recommend that you download
these if you haven't done that already. We are a group of SeemeCNC delta printer users that exist to share knowledge and friendship and would be glad
to help you with any questions or comments you may have and you can contribute ideas or knowledge to us. Happy printing when you finally get your
Orion.
Orion.
Re: Hello
Thanks Eaglezsoar. Already downloaded everything, poured through manual and have a dozen or so projects already to print. Even my wife is excited. I"ll be sure to post anything worth posting.
Re: Hello
Also does anyone know how much filament( in inches or feet) is on a 1kg spool of ABS? Approximately of course. Thanks in advance.
Re: Hello
PLA
Density: 1.25 g/cm^3.
Volume: 0.80 cm^3/g or 800 cm^3/kg
1.75 mm filament length for 1 kg spool: ~ 330 meters / ~ 1080 feet
3.00 mm filament length for 1 kg spool: ~ 110 meters / ~ 360 feet
ABS
Density: 1.04 g/cm^3.
Volume: 0.96 cm^3/g or 960 cm^3/kg
1.75 mm filament length for 1 kg spool: ~ 400 meters / ~ 1310 feet
3.00 mm filament length for 1 kg spool: ~ 130 meters / ~ 430 feet
ABS
Holy1 wrote:Also does anyone know how much filament( in inches or feet) is on a 1kg spool of ABS? Approximately of course. Thanks in advance.
