"Blobby" or "Melted" vertically thin features
wjallison1122
Post by wjallison1122 »
I have an issue with my prints that I can't seem to get rid of.
When I try to print something that is vertically thin, for example a pillar or the top of a pyramid, it looks blobby or melted.
Example:
I have a Rostockmax V3.2.
I'm using Slic3r as my slicing software.
My current temperature for printing (after a lot of experimentation) is 210.
Should the print head be moving faster for small areas? Is there a good way to do that? Do I need more airflow?
All suggestions welcome. It only takes 20 minutes to print the piece pictured, so I can try new things quite quickly.
avigeilpro
Re: "Blobby" or "Melted" vertically thin features
Post by avigeilpro »
Try to print 4 or 6 in same time, or add a "minimum time by layer". The problem here look like the layers don't have time to cool down before your printer print the next layer.
You may also want to investigate Cura. There's a number of pre-configured profiles on SeeMeCNC's git repo, here: https://github.com/seemecnc/slicing-profiles
wjallison1122
avigeilpro wrote: Tue Apr 16, 2019 6:41 pm Try to print 4 or 6 in same time, or add a "minimum time by layer". The problem here look like the layers don't have time to cool down before your printer print the next layer.
Printing multiple parts at the same time helps. I'll try adding a minimum layer time. Thanks!
