I've seen pictures on the build zone of metal arm upgrades that are called laser arms and there is a china version...
Anyone have links?
Bill
Where do you get the lazer arm upgrade
Re: Where do you get the lazer arm upgrade
tricklaser.com, light weight version
or china made metal version off of ebay
you have to specifically ask for 269mm or you will get the 250mm arms.
I haven't tested the tricklaser arms yet but they should be the mail shortly.
The china made all metal one is working out great for me, theres no slop or play in the shafts. but you do have to get your own hardware to mount them. The ball ends are snug but not tight, was able to free them a little more by throwing some grease on them.
http://forum.seemecnc.com/viewtopic.php ... 280#p10225
What key words do I use to find the ones on ebay?
Bill
Bill
Seems like I am always thanking you, it's probably because you are always helping me.
I did do a search for Rostock and found the arms, I needed for you to verify that he was the correct seller.
Thanks again
Thanks again
I saw the tricklaser arms in person tonight. They're awesome, I definitely want a set!cambo3d wrote:tricklaser.com, light weight version
I got a set of these. Seeing that you are a much handier guy than I, would you share what you used for mounting hardware?cambo3d wrote:search rostock
http://www.ebay.com/itm/Reprap-Rostock- ... 4ac2df4053
*** NEVERMIND. I FOUND IT IN YOUR BUILD LOG. ***
yes its in my build log http://forum.seemecnc.com/viewtopic.php ... 300#p11004RSMaxwell wrote:I got a set of these. Seeing that you are a much handier guy than I, would you share what you used for mounting hardware?cambo3d wrote:search rostock
I thought i posted the hardware i used but can't seem to find the post. i used 3mm x 30mm machine screws and and matching lock nuts.
edit found it: http://forum.seemecnc.com/viewtopic.php ... &start=270
