Page 1 of 10
Vertical Banding Revisited
Posted: Sun Feb 08, 2015 3:27 am
So there have been a few threads on this in the past:
http://forum.seemecnc.com/viewtopic.php?f=54&t=4203&
But I can't find a definitive conclusion. Has anybody gotten closer to solving this:
[img]
http://i.imgur.com/qUuzctT.png[/img]
Posted: Sun Feb 08, 2015 5:49 am
by Khalid Khattak
I think the infill making such banding...I use cura and i use 20% infill overlap with walls... Which gives such banding but the part is almost smooth just you can see texture like this..i normally use 0.6mm wall thickness (0.2x3 layer of each wall)... do all of your parts the same banding i.e same pattern pitch?
Posted: Sun Feb 08, 2015 8:41 am
by mlapaglia
On an unrelated note, what effector platform is that?
Posted: Sun Feb 08, 2015 10:22 am
by KAS
WoW, I'm glad you made this post. I was going nuts using the forum search and not coming up with an answer. I just switched to a E3D V6 .4 and I'm noticing the
vertical banding a lot more. I don't have the same large prints to compare, but you'll see the difference below with only the hotend and the mount being changed.
Of course they look much worse on camera than in person.
E3D V6 .4 nozzle with printed mount
[img]http://i482.photobucket.com/albums/rr189/Onuxis/20150208_100116.jpg[/img]
Rostock Max v2 Stock .5 Hotend
[img]http://i482.photobucket.com/albums/rr189/Onuxis/20150208_101605.jpg[/img]
[img]http://i482.photobucket.com/albums/rr189/Onuxis/20150208_101902.jpg[/img]
Posted: Sun Feb 08, 2015 10:31 am
by Nylocke
It could be possible that the smaller nozzle creating a thinner shell could be causing the infil lines to show through more? Do the align with the infil pattern?
Posted: Sun Feb 08, 2015 10:55 am
by KAS
Nylocke wrote:It could be possible that the smaller nozzle creating a thinner shell could be causing the infil lines to show through more? Do the align with the infil pattern?
that's hard to say for mine on the blue piece, it's a 25% triangle infill. I'll grab a pic in an hour when the walls start building up and we can correlate the infill to the sides.
Posted: Sun Feb 08, 2015 11:32 am
by jdurand
I just looked at a translucent piece I just printed, there is a slight ripple on two of the three sides of the part and since I can see the infill (10%) I can tell there's a lot more ripples than infill. I'm thinking it's the line segments printed or something like that.
I'm using S3D.
Posted: Sun Feb 08, 2015 11:44 am
by Nylocke
Maybe a larger nozzle smooths out the effects of delta segments more? Would need to know the results from the print in progress though.
Posted: Sun Feb 08, 2015 11:45 am
by Nylocke
You could isolate the possibility of infill affecting it vs delta segments by printing a large square vase with spiral vase or 1 wall no infil enabled
Posted: Sun Feb 08, 2015 12:45 pm
mlapaglia wrote:On an unrelated note, what effector platform is that?
It's the V1 platform, from before clip on arms. A disgruntled employee started running plastic parts that weren't black as a test, and they ended up in the junk pile.
Posted: Sun Feb 08, 2015 1:27 pm
by KAS
Doesn't appear to correlate to the infill. My new nozzles should be here tomorrow so I'll at least be able to try a .6 on the same hot end for a comparison.
[img]http://i482.photobucket.com/albums/rr189/Onuxis/20150208_131256.jpg[/img]
Posted: Sun Feb 08, 2015 2:33 pm
by Nylocke
What's your segments per second at? (EEPROM should be able to tell you)
Posted: Sun Feb 08, 2015 2:37 pm
Some guys on the MakerHive forum recall that changing print speed would effect this... um... effect. If it's a resonance problem, test it by changing the frequency.
I'm going to do a control piece, then print the same code with the speed multiplier turned up, and then I'll try slicing it faster as well.
Running a job at the moment, but I'll look up my segments per second too.
Posted: Sun Feb 08, 2015 2:46 pm
by KAS
Nylocke wrote:What's your segments per second at? (EEPROM should be able to tell you)
You're talking a foreign language to me
Segments/s for travel 80
Segments/s for travel printing 225
I am printing this somewhat slow at 20mm/s for inside, outside, and infill.
Posted: Sun Feb 08, 2015 3:10 pm
by Nylocke
Mines a bit lower than yours I think, but I haven't gotten really any visible banding. I print around 35-45mm/sec in Cura. I don't print a lot of flat sided objects though. I'll check it on some upcoming prints I'm doing.
Posted: Sun Feb 08, 2015 3:34 pm
by Tonkabot
Jimustanguitar wrote:Some guys on the MakerHive forum recall that changing print speed would effect this... um... effect. If it's a resonance problem, test it by changing the frequency.
I get some
vertical artifacts, and if I change speed - go slower - they go away. Mostly they are just a surface texture and I don't care if that is part of the price of printing fast.
Posted: Sun Feb 08, 2015 4:02 pm
by DavidF
I still see the vertical banding at low speeds. Im wondering if going to a 5:1 geared stepper would smooth things out?
Running rostock max V1 with rambo, e3dv6, and tricklaser arms.
Anyone notice improvement with different electronics???
Posted: Sun Feb 08, 2015 4:16 pm
by Nylocke
The extruder shouldn't make a big difference. I am using 32x drivers, that could be benefiting me.
Posted: Sun Feb 08, 2015 4:18 pm
by Nylocke
What slicing engine are we all using? I've been doing Cura. I got some segmenting on a Prusa i2 I was working on, maybe it's some sort of artifact from the slicing engine? I don't think it would be segmenting one large side, but maybe? Can't check g-code atm, riding in a car.
Posted: Sun Feb 08, 2015 4:22 pm
by DavidF
Nylocke wrote:The extruder shouldn't make a big difference. I am using 32x drivers, that could be benefiting me.
5:1steppers on the x,y,z axis...
Posted: Sun Feb 08, 2015 4:26 pm
by KAS
Nylocke wrote:What slicing engine are we all using? I've been doing Cura. I got some segmenting on a Prusa i2 I was working on, maybe it's some sort of artifact from the slicing engine? I don't think it would be segmenting one large side, but maybe? Can't check g-code atm, riding in a car.
MatterControl / MatterSlice
Posted: Sun Feb 08, 2015 4:36 pm
by Nylocke
DavidF wrote:Nylocke wrote:The extruder shouldn't make a big difference. I am using 32x drivers, that could be benefiting me.
Well that could make a difference...
Posted: Sun Feb 08, 2015 4:37 pm
by DavidF
Im using Cura
Posted: Sun Feb 08, 2015 4:55 pm
by Nylocke
Try slicing and printing this with your regular settings and then with spiral vase enabled. Then post the G-code and I'll try printing them and we can compare the results. KAS could try their hand in printing it as well, then we can all compare results. Make sure you post your diameter and flow rate settings from Cura so we can get our extrusion multipliers correct. From this we should be able to see the effect of x32 drivers and what, if any, effect the infill has on the surface finish.
Posted: Sun Feb 08, 2015 5:06 pm
by DavidF
Nylocke wrote:Try slicing and printing this with your regular settings and then with spiral vase enabled. Then post the G-code and I'll try printing them and we can compare the results. KAS could try their hand in printing it as well, then we can all compare results. Make sure you post your diameter and flow rate settings from Cura so we can get our extrusion multipliers correct. From this we should be able to see the effect of x32 drivers and what, if any, effect the infill has on the surface finish.
Will do it tomorrow, stuck doing the work thing right now
What are we trying to print anyway? File?
