Artemis 300 - Not able to calibrate zero or bed level
Quint
Post by Quint »
Hello,
I recently changed a cooling fan and nozzle on my printer and after starting it back up, I attempted to map the bed for a test print.
But, while leveling, the settings appeared to be way off. I still ran a test print and while the center appeared correct, but the print head rose progressively higher the more it travels from the center. I checked the glass bed and it is dead level across its circumference.
I checked the home position and found that the head position was off. Belt tension has been checked and the config-override.g/heightmap.csv files were deleted and created with a new 'first probe'. This wasn't successful either.
Any help would be appreciated in correcting this issue. Below are the current settings.
Thank you
Machine Status
Head Position X Y Z
0.1 2.6 524.90
Message from Duet firmware
End Artemis First Probe Autolevel Calibration
Firmware Name: RepRapFirmware for Duet 2 WiFi/Ethernet
Firmware Electronics: Duet WiFi 1.02 or later
Firmware Version: 2.05.1 (2020-02-09b1)
WiFi Server Version: 1.23
Web Interface Version: 1.21
G32
Warning: Z probe readings not consistent
config.g
M550 PArtemis ; Printer name
M555 P2 ; Repetier Output
M552 S1 ; Enable Wifi
M575 P1 B57600 S1 ; PanelDue Comm Setup
G21 ; Work in millimetres
G90 ; Send absolute coordinates
M569 P0 S0 ; Drive 0 goes forwards (X)
M569 P1 S0 ; Drive 1 goes forwards (Y)
M569 P2 S0 ; Drive 2 goes forwards (Z)
M569 P3 S1 ; Drive 3 goes forwards (E0)
M569 P4 S1 ; Drive 4 goes forwards (E1)
M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
M665 R150 L351.155 B145 H530 X0 Y0 Z0 ; delta radius, diagonal rod length, printable radius and homed height
; Y X Z are tower angle offsets
M666 X0 Y0 Z0 ; endstop offsets in mm
M350 X16 Y16 Z16 E16:16 I1 ; Set 16x microstepping w/ Interpolation
M92 X200 Y200 Z200 ; Set axis steps/mm
M92 E182.0:182.0 ; Set extruder steps/mm
M906 X1200 Y1200 Z1200 E1200:1200 I50 ; Set motor currents (mA) and idle current %
M201 X5000 Y5000 Z5000 E5000 ; Accelerations (mm/s^2)
M203 X25000 Y25000 Z25000 E25000 ; Maximum speeds (mm/min)
M566 X2000 Y2000 Z2000 E2000 ; Maximum instant speed changes mm/minute
M106 P0 H-1 ; Part Cooling Fan
M106 P2 T50 S0.5 H1 ; Heat sink fan
M307 H0 B0 ; Heated Bed (H2)
M305 P0 T100000 B4388 R4700 H30 L0 ; Bed thermistor
M305 P1 T100000 B4388 R4700 H30 L0 ; Hot end Thermistor
M563 P0 D0 H1 ; Hot end (T0), drive (E0), heater (H1)
G10 P0 S0 R0 ; Hot end operating and standby temperatures
;Dual Extrusion Code
;M563 P1 D1 H1 F1 ; Hot end (T1), drive (E1), heater (H1)
;G10 P1 S0 R0 ; Hot end (1) operating and standby temperatures
;FSR SETUP
;M558 P5 I1 X0 Y0 Z0 H5 F200 ; FSR Settings
;G31 P500 X0 Y0 Z-0.3 ; Probe trigger value and offsets
;M270 I1 P1 S0.05 ; Enabled Probe doubletap w/ 0.05mm tolerance
;M557 R140 S30 ; defualt bed mapping
;M501 ; Load saved config values
;T0 ; Select Tool 0
;STRAIN GAGE PROBE
M558 P5 I0 A2 S0.05 R0.4 H20 F2500 ; Strain gauge probe settings
G31 P100 X0 Y0 Z-0.3 ; Probe trigger and offset values
T0 ; Select Tool 0
M375 ; Load height map
Re: Artemis 300 - Not able to calibrate zero or bed level
This is your clue: "Warning: Z probe readings not consistent". Is the nozzle perfectly clean? Does the bed glass move at all?
Also make sure that the bed heat is off during calibration - the magnetic field created by the bed heater will interfere with the strain gauge circuit in the hot end assembly. (the bed can be heated up, but the bed heater must be turned off for z probing)
