Changing Spools mid print using SD card
elwooddbeauchamp
Post by elwooddbeauchamp »
I am printing from SD card, and being new at this venture, could someone share their procedure for changing to a new spool, same material, mid print on the Rostock Max v2 using the SD card...Thanks
Momma told me "You need to work on your Printing"
SoCalSteve
Re: Changing Spools mid print using SD card
Post by SoCalSteve »
I'm interested in this as well. did you ever find out anything?
Nylocke
Post by Nylocke »
In the LCD menu under the SD card menu there is a "pause print" option. Pause it, swap it, resume it. Should work fine (just try to pause it on the infil as to not screw up the perimeters).
If you have a specific spot you want to pause it and switch it at you can add some fancy G-code to lift and pause on that line.
SoCalSteve
Nylocke wrote:In the LCD menu under the SD card menu there is a "pause print" option. Pause it, swap it, resume it. Should work fine (just try to pause it on the infil as to not screw up the perimeters).
Awesome, Thanks!
elwooddbeauchamp
Thanks, Mylocke
