So I am having an issue...
I made it through the calibration and everything is great.. When I go to actually print something, I slice it and send the file to the printer- the printer starts moving and then its almost like it resets. The LCD cycles through like you just turned it on and the printer stops. I have tried it with every software I could find and it does the same thing..
Another part of the puzzle- preheating the nozzle works great but if I try and preheat the bed, it does the same thing. LCD cycles through and the printer does nothing.
Last night I took the bed off and made sure the connections were all good and there was no bridging on the solder areas. I even swapped PSUs with a bigger one and it did the same thing.
Please help! I am DYING to see this thing actually print something!!!!!
Drew
Rostock Max V2 issue!
Re: Rostock Max V2 issue!
It sounds like a short in the bed heater wiring is resetting the power supply or the power supply is defective and when the bed starts pulling a lot of current it dies and resets itself.
- Plasticator
Hi Brian, thanks for the reply.
I actually ended up running new, larger wire from the bed to the RAMBO last night, I wasn't able to test it because I blew one of those nano fuses screwing with the power wires... Hopefully Radio Shack has those!
- bvandiepenbos
I doubt that the Shack has any.
You can get them from Ultimachine
https://ultimachine.com/content/fuse-0448005mr" onclick="window.open(this.href);return false;
Is that the fuse you are looking for?
- Plasticator
Yea, that's it.. I was REALLY hoping to find some locally since overnighting a 1$ fuse from them is over $40.00!!
