Rostock MAX v2 Print not smooth
mraybon
Post by mraybon »
Hi,
I am looking a little advice be for I start taking my printer apart. Had the max v2 for 5 years and allays print fine . but lately I have started getting these lines and cant figure it out, dose it on all prints and with difference slicer. Hopeing someone can point me in a direction or a link. tried searching but don't know what to call it.
thanks so much to everyone.
see pic
https://drive.google.com/file/d/1Hq47aq ... sp=sharing
Re: Rostock MAX v2 Print not smooth
You might want to check to make sure there's no debris on the belts or in the belt path.
mraybon
Post by mraybon »
Thanks g.
I checked the belts and belt path. Adjusted the belts and still get the same print.
Is there any thing else that might be causing this?
Thanks for your help I am going crazy trying to fix this.
Are you using the original arms on your v2? If so, can you post a pic of the arm end?
tnx.
mraybon
Post by mraybon »
These are the pictures.
Thanks for your help.
Post by Mac The Knife »
Motor pulley setscrews starting to come loose maybe?
I would check to make sure that the carriages are still tight on the rails. I've had two v2s that have had broken screw pockets, primarily due to my inadvertent over-tightening of the screws. :)
mraybon
Post by mraybon »
OK I checked the carriage, its good belt are tight. used MatterControl and Cura 4.0, Printed in PLA and ABS (the light blue one). Any more suggestion or am I just stuck with this as the best it going to get?
Thanks for all the help so far.
You might want to send an email to support and send them a link to the thread.
OC33
Post by OC33 »
have you checked whether something might be dragging? i see you have new carriages but maybe the pulleys at top and bottom could be dragging some? it could even be that one of your stepper motors may be having an issue? another thing is whether your set screws on on your "stepper motor belt wheel" (cant recall the proper name for it :lol: ) could be loose and shimmying as it moves? Wish you luck!
Return to “Rostock MAX v2”
