I don't think anyone has broken this part before
Can anyone recommend an epoxy/glue to hold my arm on? This is in a heated chamber (the heated bed is the only heat right now).
Re: I don't think anyone has broken this part before
I had a failed print start a filament "snowball" that ended up pulling the wires out of my fans. Glad you escaped relatively unscathed.
[img]http://i.imgur.com/rRNzYs1.png[/img]
I'd think you could get the clamping action going with a couple bolt/washers/nut assemblies stuck between the axle and the back of the assembly where you broke the fingers.
Another idea, wire or zip-ties to a cross support (bit of pencil, maybe).
In any case, first thing I'd print is a new effector plate.
Silly question, but you know you can buy a new one, right?
http://seemecnc.com/collections/parts-a ... ostock-max" onclick="window.open(this.href);return false;
LOL!Jimustanguitar wrote:Silly question, but you know you can buy a new one, right?
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
I would think he didn't; that is a lot of work and even more in cleanup for $10!
Thank you for the reminder and link, as it is invaluable to have replacement parts at your disposal.
- Mike
Was that just added or am I blind? Probably the second one
. I'll grab that if the epoxy fails again. Thanks!
![Smile :)](./images/smilies/icon_e_smile.gif)
