EZ Struder instructions?
Does anyone have instructions on how to assemble the EZstruder?
Re: EZ Struder instructions?
Jesse, please see Section 12 in this draft of the 2nd edition manual: http://www.geneb.org/rostock-max/Rostoc ... -Guide.pdf
Thanks Gene.
What changes need to be made to the firmware to support the EZ Struder?
E0 steps per mm. (or E1, if you have it wired that way) I don't know what the proper value should be.
You could probably also do some speed and acceleration tweaks.
- Plasticator
Can someone identify what screws are to be used here? None of the ones remaining in my kit seem to work.
You should have 1 2" #6-32 and 1 1.75" #6-32 pan head screw. Use those and two #6-32 nylon lock nuts.
- Plasticator
thanks,
