How's the dimensional accuracy?
Posted: Tue Aug 16, 2016 2:15 am
by 626Pilot
I've been thinking about getting one or two of these to augment my production line. I need to be able to print parts that interlock with other parts, with fine tolerances. I was wondering if anyone has done any testing on this printer to figure out what sort of dimensional accuracy it can deliver. I have a
dimensional accuracy calibration procedure that works with delta printers, and which should fit within the Eris' footprint. However, you could just print something out and measure it with calipers, if you don't want to go through the calibration.
Re: How's the dimensional accuracy?
Posted: Tue Aug 16, 2016 7:34 am
by Mac The Knife
I believe it's pretty good. However I quit using the auto-cal feature, and make adjustments in the eeprom. I'll have to print out a test cube this morning.
Posted: Tue Aug 16, 2016 8:06 am
by joe
626Pilot wrote:I've been thinking about getting one or two of these to augment my production line. I need to be able to print parts that interlock with other parts, with fine tolerances. I was wondering if anyone has done any testing on this printer to figure out what sort of dimensional accuracy it can deliver. I have a
What are you making with your production line? You seem a smart fellow, why not build your own printer to your exact specs?
Posted: Tue Aug 16, 2016 8:21 am
by Mac The Knife
Sketched up a 1 x 1 x .5 inch cube, in Solidworks, .05 wall thicness. It measured a thousandth under in Y, and around 6 thou over in X. Wall thickness measured 5 thou over. Sliced with S3d, .2mm layer height, .5mm nozzle, Hatchbox pla. Printed on PEI, sanded with 400 grit.
Posted: Tue Aug 16, 2016 10:53 am
by joe
Mac The Knife wrote:Sketched up a 1 x 1 x .5 inch cube, in Solidworks, .05 wall thicness. It measured a thousandth under in Y, and around 6 thou over in X. Wall thickness measured 5 thou over. Sliced with S3d, .2mm layer height, .5mm nozzle, Hatchbox pla. Printed on PEI, sanded with 400 grit.
are you swapping between units? inches/mm
Posted: Tue Aug 16, 2016 11:32 am
by Mac The Knife
Yep, drawn in imperial, sliced in metric. I am overextruding though,,, It shows at the corners, and the top layer of the bottom of the box was printed concentric, and it shows over extruding there also.
Posted: Wed Aug 17, 2016 1:10 am
by 626Pilot
joe wrote:What are you making with your production line? You seem a smart fellow, why not build your own printer to your exact specs?
Some things that I designed myself, and some things for customers. I have already built a MAX METAL, and will be starting in on a second one soon. They are excellent printers. However, the BOM for these printers - to deck them all out the way I want them - is close to two grand, and they take awhile to assemble and calibrate. The Eris is only $550+shipping, and someone else has already figured out all the annoying details for me. All I have to do is add a Raspberry Pi with OctoPrint, and that's all. No dozens of hours spent printing fixtures, etc. The Eris only has one nozzle, and no bed heat, but it's still good enough to do a lot of things.
Posted: Thu Aug 18, 2016 3:09 am
by 626Pilot
Alright, I've seen measurements from a few people (some on YouTube) and I'm satisfied. Pulled the trigger
