Hello All, I assembled a Droplit machine some months ago and i recently got another resin (3DInk Orange) to test with the Droplit.
I was able to print a small toy figure that ended up like the pictures on the link below:
https://photos.google.com/share/AF1QipO ... V4WEJoazln
The problem is that i need to have 2 limit switches/end stops because the platform already broke 2 glass plates for going below the VAT/glass
plate level causing a unbelievable mess.
Sometimes, when i use Creation Workshop and try to move the Z-axis up, it goes down instead and does not stop so it keeps going down until it brakes the VAT/glass
and the carriage reaches the bottom and it cannot go further. Out of panic i turned the machine off but after inspection there was some dents left in the melamine from the force
of the motor/platform hitting the bottom where the carriage stopped.
So, you can see this kind of problem is very prejudicial.
My problem is:
I have the upper limit switch installed and working but i cannot figure out which pins to use to install a lower limit switch in
the GSHIELD V5 board.
I have two wires for the upper limit soldered at positions : GND and D11 in GSHIELD V5.
Should i connect the lower limit switch wires in the same positions as the upper limit ones?
I appreciate help from anyone who has experience with this kind of problem.
Thank you
Andradez
How to set up two Z axis limit switches in Droplit?
Troubleshooting topics around resin based printing
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- Software
- ↳ Orca Slicer
- ↳ SuperSlicer
- ↳ Cura
- ↳ Simplify3D
- ↳ Slic3r
- ↳ KISSlicer
- ↳ Repetier Host
- ↳ OctoPrint
- ↳ Other
- ↳ Sculptris
- ↳ OpenSCAD
- ↳ FreeCAD
- ↳ Blender
- ↳ SolidWorks
- ↳ AutoDesk 123D
- ↳ EMC2/LinuxCNC
- ↳ Skeinforge
- ↳ Mach3 Software
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
