Saltwater Vat
Resins, sources, hybrid mixes, made-at-home and more
brent
Saltwater Vat
Post by brent »
So, Kyrre Aalerud (aka: KreAture) on the freenode #reprap IRC and I were talking about ways to make a better non-stick vat coating that is cheap.
He came up with a method using saltwater:
*Pour 1mm of saltwater (table salt) into your vat
*Pour resin on top of the saltwater layer, it should float
*Adjust starting layer height to account for the saltwater
I have not tested this method yet (don't have a droplit), but I am very eager to hear people's feedback and results.
sgraber
Re: Saltwater Vat
Post by sgraber »
This is how the Peachy Printer does it. I personally don't recommend it, as there are certain components a resin formulator can use in a resin that might be more water soluble than soluble in the resin and it could leech out. Plus I think this would also cause a problem of the layer moving in a wave-like pattern every time the build platform came down into the resin. Try it and see what happens though!
Glacian22
Re: Saltwater Vat
Post by Glacian22 »
I've tried this, and there are two really tricky parts that made me give up on it. First, the whole system is extremely vulnerable to vibration, so if someone slams a door nearby you could end up with an uneven layer cure. Second, when you raise the buildplate up after a completed layer, you need to give it a really long chunk of time for the water+resin to settle and stop rippling.
That not to say it can't work, but that's just what made me decide against it.
brent
Re: Saltwater Vat
Post by brent »
Glacian22 wrote:I've tried this, and there are two really tricky parts that made me give up on it. First, the whole system is extremely vulnerable to vibration, so if someone slams a door nearby you could end up with an uneven layer cure. Second, when you raise the buildplate up after a completed layer, you need to give it a really long chunk of time for the water+resin to settle and stop rippling.
Thank you for your thoughts, I'm glad someone has tried this and has an answer.
Return to “Resin Materials”
