Blew a fet
Posted: Fri Apr 08, 2016 10:46 pm
by bubbasnow
well my 2.6 fan shorted out on my hotend today. blew this guy up!
https://goo.gl/photos/C49YDPd1cCjU1hww6
Also fried my t1 adc it looks like. it just sits constant at 22.3 deg and does not change values to "inf" when i remove the connection from my board.
Re: Blew a fet
Posted: Fri Apr 08, 2016 11:00 pm
Can you send the card in for repair?
Re: Blew a fet
Posted: Fri Apr 08, 2016 11:16 pm
by bubbasnow
ZXMN4A06GTA is the fet part number, they only cost 2 bucks so its probably not worth it to send it back. The weird thing is that damn T1 temp sensor holding a value when OL. which means i might have damaged the adc or some of the components that its wired to.
Re: Blew a fet
Posted: Sat Apr 09, 2016 12:01 am
bubbasnow wrote:ZXMN4A06GTA is the fet part number, they only cost 2 bucks so its probably not worth it to send it back. The weird thing is that damn T1 temp sensor holding a value when OL. which means i might have damaged the adc or some of the components that its wired to.
The ADC is probably not so easy to remove from the board and replace so you may end up sending it back to the manufacturer after all. Here's to hoping
that you can repair it your self.
Re: Blew a fet
Posted: Sat Apr 09, 2016 12:08 am
by bubbasnow
you are quite right, this is probably directly to the cpu. not going to attempt that mess.
