Cooling fan constantly on
Posted: Fri Mar 18, 2016 10:54 am
I have an Azteeg X5 running on my delta, and just recently my cooling fan won't shut off. Normally, when I power it up the cooling fan's off with no issues, and it stays off as it should until the second layer of the print. Now it's on constantly. I haven't changed anything in the config with relation to the fan setting. M107 won't stop it - it's just alwys on.
These settings have been the same since I had originally set this up. I've even compared it to some archived config files I've saved and they're the same. But now my fan won't turn off??? Any suggestions?
Thanks in advance,
~C.
# Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 2.4 #
Thanks in advance,
~C.
