Hi guys. Been a while since I posted my normal basic topics.. Here's another one. Whats the length of material on the SeeMeCNC .5kg spool (1.75 ABS)?? When I load a model in Cura it tells me how much length is required, and I'm not sure how much the .5KG holds.
On another note, if a print is happening and the spool is about to run out, what is your process to join another spool into the mix? Or is that not possible?
Weight versus length
Re: Weight versus length
I have paused the print, pulled out the old filament and put the longer piece in and resumed printing, The results after a moderate amount of sanding were good. My only issue was that i was shining LEDS through it, and you could tell the difference in quality between matterhackers and hatchbox filament (matterhackers was much whiter - better).
As far as length per kg, that depends on the density of the material, and it varies even between different colors of ABS.
Approximations:
PLA
Density: 1.25 g/cm^3
Volume: 0.80 cm^3/g or 800 cm^3/kg
1.75 mm filament length for 1 kg spool: ~ 330 meters / ~ 1080 feet
3.00 mm filament length for 1 kg spool: ~ 110 meters / ~ 360 feet
ABS
Density: 1.04 g/cm^3
Volume: 0.96 cm^3/g or 960 cm^3/kg
1.75 mm filament length for 1 kg spool: ~ 400 meters / ~ 1310 feet
3.00 mm filament length for 1 kg spool: ~ 130 meters / ~ 430 feet
https://www.toybuilderlabs.com/blogs/news/13 ... and-length
Approximations:
PLA
ABS
I've used this calculator a bit to give me a reasonable idea of how to convert length to weight:
http://3deee.ch/3deeeMaterialCalculator4.php
