Snow-White ABS?
- Renha
Snow-White ABS?
Hello. I've tried to find snow-white ABS, but best I've found was between white and natural color.
Another issue is that I am living in Russia, and with all that rouble falling and postage prices I couldn't order filament just to see what color is it in real.
Anyone have seen somewhere ABS as white as white PLA?
3D printing is magic!
Re: Snow-White ABS?
I have used ookuma filament that was called snow white.
It was white, not sure i can describe the tone of white.
It worked well.
Afaik they ship internationally.
It worked well.
- Windshadow
Re: Snow-White ABS?
this miracle white is what comes up using this search system for white white
Thanks for your interest for Filaments.directory.
There is already nearly 1000 filaments inside the database !
The search engine haves 16 parameters.
Please, take the time to try the color search.
Here is your link to the private beta :
https://www.filaments.directory?key=jVFCFesGNxWlrqrP" onclick="window.open(this.href);return false;
All Professional 3D Miracle ABS White
Company
Country United States
Continent North America
Type Manufacturer
Product
Plastic ABS
Weight 1 kg
Diameter 1.75 mm
Tolerance ± 0.05 mm
Spool Yes
Official price per spool ± 23.95 USD
Price / kg ± 24 USD/kg
Min Printing T° 230 °C
Max Printing T° 230 °C
Color
RGB
Company
Type Manufacturer
Product
Plastic ABS
Weight 1 kg
Diameter 1.75 mm
Tolerance ± 0.05 mm
Spool Yes
Color
RGB
- Renha
Re: Snow-White ABS?
I've tried Filaments.directory, but:
1) all All Professional 3D white filaments (ABS, PLA, ...) are marked as perfect white - suspicious
2) photos of All Professional 3D Miracle ABS white shows not so white.
- Captain Starfish
Re: Snow-White ABS?
I use the white ABS from doodaddoes.com.au, I believe it's extruded by a Melbourne company.
It's pretty white.
Dunno how it compares to anything else though. Perhaps you could as Isaac for a sample?
It's pretty white.
- Prints-a-lot
Re: Snow-White ABS?
Verbatim white is white.
Re: Snow-White ABS?
Ultimachines white ABS is white, but it's not cheap by any stretch.
For some reason white is a color I don't like ABS in.
- Renha
Re: Snow-White ABS?
Thanks all for answers!
I think i'll start with Verbatim, looks like I have found local reseller.
Polygonhell, why don't you like it?
- Captain Starfish
Re: Snow-White ABS?
Biggest problem I have with white prints is that because of their porous and textured finish (fairly unavoidable result of printing) they get real dirty real fast and they are impossible to get clean.
- Renha
Re: Snow-White ABS?
Acetone vaporing doesn't help?
Re: Snow-White ABS?
I don't like it, because It always looks very unnatural to me, like it's been bleached, and the surface tends to have a matt appearance.
The only reason I know Ultimachines White ABS is white is because I ordered it accidentally when what I wanted was their natural.
I did print the TRex Skull in it and it does look good for that print.
