Within MatterControl, at various times, I am required to disconnect and reconnect to my printer. To clarify, I have to click the "Disconnect" and "Connect" button at the upper left of the screen. I don't have a firm understanding or when or why it occurs. Some clues are:
- I see this issue most often during my preparation towards starting a print. Specifically, I manually preheat my printer (nozzle and bed), wait a while for the hot end to heat up, and then I intend to extrude about 30mm of filament manually. However, when I click the E+ or E- buttons for manual extrusion, nothing happens. After this, I disconnect and reconnect, and then I'm mysteriously able to extrude.
- I definitely remember a case in which I set the nozzle and heatbed temperatures, and MatterControl claimed to have the target set appropriately. However, the LCD on the printer told me otherwise (target temperatures were both at 0). I tried other temperatures from MatterControl, but no changes occurred on the printer. After disconnecting and reconnecting, the problem went away.
- I do not have any disconnection problems during prints (and I'm not touching any controls at this point either).
- I vaguely remember having similar troubles with manual movement operations too. I could not move the print head unless I disconnected and reconnected.
