Extruder motor does'nt start
Posted: Wed Sep 14, 2016 12:12 pm
by Khayrisill
Hi everybody !
Something weird with S3D, when i launch the build the extruder motor does'nt move. I can move manualy thru the control panel. And its works perfevtly with mattercontrol.
Someone has one idea ?
Re: Extruder motor does'nt start
Posted: Wed Sep 14, 2016 2:05 pm
by KAS
Under the FFF settings, which "Extruder Toolhead Index" do you have selected? I believe default is Tool 0, but you can try the others to make sure. If you can move the extruder through the S3D control panel, then just make sure it matches the "Active Toolhead" listed on that screen.
Posted: Wed Sep 14, 2016 7:14 pm
by Khayrisill
Tool 0 is selected. nd i see nothing in control panel.
Posted: Thu Sep 15, 2016 7:14 am
by KAS
Here is the location in the control panel.
Posted: Thu Sep 15, 2016 10:01 am
by Khayrisill
I just restart everything. Know it works. Tool 0 is selected.
Thanks KAS.
