Questions on performance and upgrades
Posted: Thu Feb 19, 2015 12:28 pm
I'm planning on purchasing a second printer, and I'm seriously considering a Rostock MAX, but I have many questions that I'd like to have answered before I make the purchase. Thanks in advance to anyone who answers my questions.
Speed and Stability:
1. How fast do you usually run your Rostock Max? The sales site says 30-60mm/s, but that's a wide range and I'd like to know what speed most people use in real life.
2. How robust is the frame? Am I going to see a loss in stability as the hot end moves away from the base? Does the stability change if I add weight to the top of the frame (multiple filament spools, books, coffee cups, etc.)?
3, Has anyone gradually added weight to the effector to see at what point stability issues are seen at high speeds?
Heated Bed:
4. My Mendel had issues with heating the bed evenly when it was just a PCB and glass setup. I saw a big improvement when I added an aluminum plate. How evenly does the bed get heated on the Rostock MAX? Is it worth adding an aluminum plate?
Automated calibration:
5. I've seen mods for automatically calibrating delta printers. How often will I need to recalibrate a Rostock MAX? Is automating the calibration something worth pursuing?
Heated Bed:
