First Print on my Max V2!
Posted: Wed Mar 19, 2014 9:47 pm
by dgriff
Yup, worked perfectly on the first try!
https://www.youtube.com/watch?v=auTGFhSS4is
I'm really impressed with the accuracy of the print!
Re: First Print on my Max V2!
Posted: Wed Mar 19, 2014 10:06 pm
by joecnc2006
Nice, What speed did you have it set at, and is the ABS or PLA? I imagine ABS since no cooling fans yet.
Posted: Wed Mar 19, 2014 10:15 pm
by dgriff
joecnc2006 wrote:Nice, What speed did you have it set at, and is the ABS or PLA? I imagine ABS since no cooling fans yet.
For this one I just had it set with the stock SeeMeCNC ABS settings (yup, ABS for now), which is 100% speed.
Looks like it needs a tiny bit of cleanup, but not very much!
Posted: Wed Mar 19, 2014 11:07 pm
I am also impressed with the accuracy of the print, an excellent job of building and calibrating the printer.
Posted: Wed Mar 19, 2014 11:59 pm
by Tinyhead
Except for the little overhangs on the left side, that looks REALLY smooth! Excellent work!
Posted: Thu Mar 20, 2014 12:15 am
by dgriff
So it's close, but not quite a cigar.
When it finished, I found the PEEK fan wouldn't fit, so I did some measuring and found that it was just a bit off.
Original Image:
[img]http://i.imgur.com/uUKIWXjs.jpg[/img]
Dimensions:
[img]http://i.imgur.com/rLGYWLps.jpg[/img]
So it's printing slightly askew - to the tune of 1mm, but enough that the fan won't quite fit. The dimensions at the bottom of the print seem much closer to the .stl model than at the top.
Any ideas what would be causing this?
Dave
Posted: Thu Mar 20, 2014 12:25 am
by joecnc2006
Did you print a cube and check your sq.
Posted: Thu Mar 20, 2014 12:46 am
by dgriff
joecnc2006 wrote:Did you print a cube and check your sq.
Nope, was just following the orders... er... instructions :). Was worried about damaging the PEEK nozzle if I didn't get the cooling fan in-place relatively quickly. Or does that just help the print quality?
Was getting late so didn't have time to try another print - I'll do the cube first thing tomorrow. Which adjustments should I be looking to make if the cube isn't perfectly square?
Dave
Posted: Thu Mar 20, 2014 2:06 pm
by dgriff
Just a quick update - tightened up the belts a bit more and did another test print - FAR better.
Found a good way to tighten the belts (at least for me) was to take apart a wooden clothespeg and use the two sides as shims to apply tension and adjust the upper bearing.
Had another thought that I might print myself an ABS "belt tightening wedge" that has two equal shims that are connected at the near end so I can slide it under, adjust tension and keep everything level on both sides.
Edit: Also had to dial-down the extrusion multiplier in the slic3r settings to 0.7 to get the flow correct. Think I need to calibrate the extrusion settings a bit more, but it's getting more and more accurate the more I play with it. Hopefully the final step is a tiny bit more work on a couple of the delta arms that are just a bit too tight. Thinking a dab or two of lubricant should help.
Posted: Thu Mar 20, 2014 2:42 pm
by neurascenic
Or this
http://www.thingiverse.com/thing:146815
Is on my soon to print list.
Posted: Fri Mar 21, 2014 7:44 pm
by dgriff
neurascenic wrote:Or this
That's a pretty nice design - won't work as-is with the V2 due to changes in the top idler build (there's a melamine piece at the top of the idler tower that the top plate screws into), but it could probably be adapted with a bit of work.
Since my last post, I've dialed in the extrusion rate multiplier quite accurately, and combined with the belt tightening, it's almost completely solved the error in my original prints. PEEK fan shroud came out fine and the fan popped in easily, and I'm doing the PLA blower duct right now.
Posted: Fri Mar 21, 2014 8:51 pm
Didn't that first print feel good?
Posted: Tue Mar 25, 2014 1:13 pm
by dgriff
First print felt great! I finally got everything dialed-in, and printed the PLA blower as well:
[img]http://i.imgur.com/AJKjqVos.jpg[/img]
Fits perfectly and printed this at 100% feed and 100% flow. Now I just need to work on the bridging settings a bit to fine tune them, then I can start printing stuff for fun!
In the meantime, thinking of switching over to PLA. Any thoughts on PLA vs ABS on the Max?
Posted: Tue Mar 25, 2014 2:01 pm
dgriff wrote:First print felt great! I finally got everything dialed-in, and printed the PLA blower as well:
Either filament should print fine on the Max. To me it's just a personal choice on which to use. With PLA you would want to enable cooling when
you slice the part and the average bed temperature would be approximately 60c. There are some interesting topics about using hair spray to help
the part stick to the bed and with PLA you can use paper that you adhere to the glass. PLA sticks great to paper and if some sticks to the part you
just need to rinse under some water and the paper will come off. Works great and no glue or hairspray is needed except for the spray adhesive you
put on the paper to hold it to the glass.
Posted: Thu Mar 27, 2014 2:15 pm
by dgriff
Tried a much larger print last night - the edge resolution is fantastic. Had some problems with the top as I only did a 10% infill for test purposes. Still, pretty cool!
[img]http://i.imgur.com/tAmWU3Ss.jpg[/img]
Dave
Posted: Thu Mar 27, 2014 3:04 pm
dgriff wrote:Tried a much larger print last night - the edge resolution is fantastic. Had some problems with the top as I only did a 10% infill for test purposes. Still, pretty cool!
Dave
Looks great for a first time print. Good job!
Posted: Sun Mar 30, 2014 1:16 am
by dgriff
So my wife wanted a pony... I made one for her!
[img]http://i.imgur.com/kzYbQSis.jpg[/img]
With supports removed (but still needs more cleanup...)
[img]http://i.imgur.com/zbCl6QYs.jpg[/img]
Not too shabby! Might need a bit more work on the speed/retraction settings, especially for fine details (this was my first print with my tweaked Cura settings), but I'm pretty happy with it.
Posted: Sun Mar 30, 2014 7:12 am
I think the pony came out great for an early print.
I bet your wife loved it! Good job!
Posted: Sun Mar 30, 2014 10:45 am
by Tinyhead
Dave
Nice! Not sure what slicer you're using, but i found Cura seals up the top surface areas much better than Slic3r. I'm sure if you're better versed than myself with Slic3r that you could figure it out, but i couldn't seem to get things right when it came to nicely sealing the top.
