Max v2 hot end problem & upgrade
Posted: Tue Dec 17, 2019 5:42 pm
So I've had this machine since 2015 and its given me lots of good prints and absolutely no trouble...until the past few weeks. The hot end will not reach the required temp & stays about 5 to 8 degrees below set temp. No mater what the setting is, 195 , 200, 210 its stays at that delta below the set temp.
From reading the forums this sounds like a malfunctioning resistor heater. Is the 5.6 ohm resistance heater what I need?
If I were to replace the entire hotend would that be with the SE300?
Thanks for any advice on this.
Regards
Regards
