HE280 seems to have stop heating up
Posted: Thu Sep 28, 2017 6:34 pm
So I have been using my ROSTOCKMAX v2 with my new HE280 for a number of projects over the past 3 weeks.
Probably put in 100 or more hours of printing with no issues at all.
All of a sudden, on my next print the hot end will not heat up.
When I manually adjust the extruder temp on the LCD panel, I can see the two red lights on the board start flickering
but the temp just remains at room temp.
The bed heats up with no issue.
I checked that the connector was plugged in properly and i checked and replaced the fuses just to make sure they were fine.
Wiggled the wiring around thinking maybe I have a loose wire but no joy.
Finally, I reset and reloaded the EPROM and it still will not heat up.
I do not even hear the fan load up slightly like it does when I turned the hot end on before the issue.
Any assistance would be much appreciated because we all know if a machine is going to give you issues, it will do it right in the middle of a project.
Thanks,
Tom
Thanks,
Tom
