Flying cold end?
Posted: Mon Jul 03, 2017 4:57 pm
by VAXHeadroom
Has anybody seen/built a non-bowden tube flying hot/cold extruder for the V2? I've seen the suspended systems. The general wisdom is that the stepper is too heavy to fly but I'd be willing to go slow in order to get rid of the bowden tube setup...
Re: Flying cold end?
Posted: Mon Jul 03, 2017 6:01 pm
by Tincho85
I used to have my cold end extruder "flying" above the effector, but there is still a bowden tube connecting it to the hotend. I ditched it... not because of the weight, as it was using a counterweight pulley, but because of the mass. When the machine was printing, the flying extruder bounced when rapid moves occurred. That made the edges come out non-straight.
(sorry for that poor english, I tried my best
As for a direct drive extruder for the V2 I personally recommend the Titan Aero, just because that is what I'm using. To compensate for the extra mass/weight, Jerk and acceleration were reduced, but I'm still printing reasonably fast. 60mm/s print and 200mm/s travel moves.
Some folks around here have the Nimble (remote direct drive), but can't talk about it as I never tried it myself.
Posted: Mon Jul 03, 2017 11:41 pm
by VAXHeadroom
Thanks, exactly the kind of information I was looking for
-- Emory
P.S. Your English is fine!
Posted: Tue Jul 04, 2017 3:47 am
by nebbian
To stop the extruder bouncing you can make three of these:
https://www.thingiverse.com/thing:2058541
I really like flying extruders. Much better output than a big long bowden tube.
Posted: Sat Jul 08, 2017 12:11 am
by VAXHeadroom
Tincho85 wrote:...
What stepper motor are you using with the Titan Aero?
Posted: Sat Jul 08, 2017 12:51 pm
by Tincho85
Hi, I'm using the recommended stepper from E3D.
They call it Nema17 Slimline:
http://e3d-online.com/Electrical/Steppe ... n-Slimline
Some people are using and even smaller one, which is +/- 30g lighter but with a 1.8º stepping angle vs the 0.9º of the Slimline.
Like this one:
https://www.filastruder.com/collections ... pper-motor
If you are considering getting the Titan Aero I've already made a mount for the Rostock Max.
Check out this thread:
http://forum.seemecnc.com/viewtopic.php?f=35&t=12014
Posted: Mon Jul 10, 2017 11:04 pm
by VAXHeadroom
PERFECT. Thanks for the info, I'm almost certainly going to duplicate your setup!
-- Emory
