Want to hire a printmaster for remote troubleshooting
Posted: Thu Jun 15, 2017 1:20 pm
Hi all,
I am looking for a "Printmaster" who owns or has access to a Rostock Max V2 who I could hire to work remotely with our technician to try to troubleshoot some problems we are having.
We are a small start-up getting ready to launch a new product and want to 3D print our plastic enclosure for the first 50 to 100 beta-test units until we are sure the design won't need to change. When sales volume and cash flow permits, we will transition to a plastic injection molded enclosure.
We have been using a Rostock Max V2 for about a year, but lately our technician is having trouble getting reliable prints. We are located in eastern Canada so it would be best if the person was located in North America, even better if they are on the east coast so the time zones will line up better. I'd like to be able to have my technician send you our files, and have you slice and print it on your printer in ABS to see if you can can help us figure out what the problem is.
Things were printing flawlessly in ABS about a month or so ago using Cura for our slicer, but then all of a sudden we started having problems with gaps in walls, dimensional accuracy being off. We are also using ABS filament purchased from SeeMeCNC. My technician has tried bed leveling, extrusion width, extrusion multiplier, flow rate, extruder temp, etc. but he is still not able to get good prints. He has been consulting the following guides in an attempt to fix the problems.
https://www.simplify3d.com/support/prin ... eshooting/
http://support.3dverkstan.se/article/23 ... ting-guide
One problem in particular is that the slicer is not slicing the print model walls properly (without gaps) unless the setting for the diameter of nozzle is decreased from 0.5mm to about 0.4mm. He had no issues with prints using 0.5mm for a nozzle setting in the past.
Tthe other main problem is dimensional accuracy, we are getting a dimension of 21.5mm for a 20mm cube and 70.5mm diameter instead of 65mm for one of our parts that we used to be able to print with no problems.
My technician has been filing support tickets with SeeMeCNC but they have not been able to help us resolve the issues yet and we are burning through lots of personnel time.
If this something someone would be interested in helping with, please contact me and let me know what you would charge for your time. We could pay for a couple of hours of time through Paypal to get things going.
If you are not interested but can recommend someone else that would be appreciated.
My email for further correspondence is [email protected].
Sincerely
Kelly Galloway
ETC/Dynamic Monitors
Sincerely
Kelly Galloway
