Custom Controls Thread
Posted: Sat Feb 08, 2014 10:41 pm
Here are some useful custom controls I've created for the RostockMax and Repetier. If anyone else has any please feel free to add to this. Octoprint's Github has a great guide and some good examples.
Just place these in the controls section of config.yaml.
Bed Calibration:
This will create custom controls that make calibration go much quicker.
Basically, enter a value into the box and it will lower the nozzle to that height at which ever calibration point you want. From there use the LCD to lower it step by step.
EEPROM Updater
This block does a few things. First, it allows you to update a specific EEPROM value, or update PID values. Second it looks for specific EEPROM values and will save them. This makes it easier to keep track of the M503 output (the terminal only keeps them for so long.) Someday, I will make a complete list of EEPROM values.
Bed Calibration:
- children:
- commands:
- G28
- G0 Z%(height)s F1500
input:
- default: 5
parameter: height
type: parametric_commands
- commands:
- G28
- G0 X0 Y90 Z%(height)s F1500
input:
- default: 5
name: G0 X0 Y90 Z
parameter: height
name: Zero Z axis
- commands:
- G28
- G0 X77.94 Y-45 Z%(height)s F1500
input:
- default: 5
name: G0 X77.94 Y-45 Z
parameter: height
name: Zero Y Axis
- commands:
- G28
- G0 X-77.94 Y-45 Z%(height)s F1500
input:
- default: 5
name: G0 X-77.94 Y-45 Z
parameter: height
name: Zero X Axis
type: section
EEPROM Updater
- children:
- commands:
- M206 T3 P145 X%(maxLength)s
- M206 T3 P149 X%(maxLength)s
- M206 T3 P153 X%(maxLength)s
- M500
- G28
input:
- default: null
name: Max Z height
parameter: maxLength
name: Set XYZ max length
- commands:
- M206 T%(type)s P%(location)s X%(value)s
- M500
- G28
input:
- default: null
parameter: type
- defualt: null
parameter: location
- default: null
parameter: value
- commands:
- M206 T3 P218 X%(pgain)s
- M206 T3 P222 X%(igain)s
- M206 T3 P226 X%(dgain)s
- M500
input:
- default: null
parameter: pgain
- default: null
parameter: igain
- default: null
parameter: dgain
type: section
- children:
- command: M114
regex: X:([0-9.-]+) Y:([0-9.-]+) Z:([0-9.-]+) E:([0-9.-]+)
template: 'Position: X={0}, Y={1}, Z={2}, E={3}'
type: feedback_command
- command: M503
type: command
- name: Z Height
regex: EPR:([0-9.-]+) ([0-9.-]+) ([0-9.-]+) X max length
template: ' {2} |Type: {1} | Location: {0}'
type: feedback
- command: M503
regex: EPR:([0-9.-]+) ([0-9.-]+) ([0-9.-]+) Extr.1 PID P-gain
type: feedback
- command: M503
regex: EPR:([0-9.-]+) ([0-9.-]+) ([0-9.-]+) Extr.1 PID I-gain
type: feedback
- command: M503
regex: EPR:([0-9.-]+) ([0-9.-]+) ([0-9.-]+) Extr.1 PID D-gain
template: '{2} |Type: {1} | Location: {0}'
type: feedback
- name: Printer Radius
regex: EPR:([0-9.-]+) ([0-9.-]+) ([0-9.-]+) Horizontal radius
type: feedback
type: section
