help me
Posted: Sun Apr 06, 2014 2:20 pm
by ector
I recently finished building the rostock 3d printer and I have began to calibrate it. I have ran into a problem because when it moves parallel to the build platform in both the x and y axis, it dips up and down in a bowl shape. I don't know how to fix the problem. The nozzle is at the perfect height in the center and is too high in all the corners. Please Help!
Re: help me
Posted: Sun Apr 06, 2014 3:19 pm
by JohnStack
Complete the calibration process. Horizontal Radius Settings Specifically.
Page 224.
Re: help me
Posted: Sun Apr 06, 2014 4:38 pm
by ector
can you give me the link?
Re: help me
Posted: Tue Apr 15, 2014 7:28 pm
ector wrote:can you give me the link?
http://download.seemecnc.com/rostockmax ... -Guide.pdf" onclick="window.open(this.href);return false;
Page 192
Re: help me
Posted: Fri Sep 18, 2015 9:13 pm
by GPriv
I printed a little thingy... all worked out fine.
Did more reading, tried another thingy to print and now the printer is begining the first layer halfway up the Z axis! HUH???
What happened?
Thanx in advance.
Re: help me
Posted: Sat Sep 19, 2015 3:52 pm
by Earthbound
Step 1. Go back and print the first little thing (the one that printed correctly). If it prints correctly again, then you will know the problem is with the other model file or settings when it was sliced. If you can no longer print the first thing correctly, you'll know something about the printer has been changed.
Re: help me
Posted: Sat Sep 19, 2015 3:57 pm
by GPriv
Yup. Did that. Then, downloaded a file to print from seemecnc site. Same thing.
SO.... I did a thorough virus check, and sure enough there was one. Also, I noticed that there were two printers (both the same only one was named and the other was not) on MatterControl. I deleted ALL files from Repitier...thoroughly, again. manually deleted anything on 'puter I could find. And reinstalled, re-calibrated, everything. Works fine now for first print. Just now checking to see what happens when I download that same larger file.
Thanx!
Re: help me
Posted: Sat Sep 19, 2015 4:02 pm
by GPriv
Re: help me
Posted: Sat Sep 19, 2015 4:13 pm
by GPriv
How do you print from an SD card? I've loaded the SD card with the file...cannot figure out what to do next.
Thank you in advance.
Re: help me
Posted: Sat Sep 19, 2015 5:27 pm
by Earthbound
Slice model in MC.
Save gcode on computer.
Stick SD card in computer and copy gcode to SD card.
Move SD card to printer.
If printer was on when SD card was inserted, will automatically open file selection directory.
Otherwise go to Select File...
It is also possible to export gcode from MC to SD card while SD card is in the printer, but file transmission to RAMBo over the USB link is slow. Much quicker to swap card back and forth. Also, allows you to leave USB cable from printer disconnected, which you want to do while printing - prevents printer from rebooting mid-print if computer re-initializes USB port.
Re: help me
Posted: Sat Sep 19, 2015 5:31 pm
by Earthbound
On that very large (covers most build of plate diameter) object, make sure your non-printing "travel" movement speed is not more than about 150mm/s.
Re: help me
by GPriv
Okay...so I did all and NOZ and Bed are heating up.
All good?
Can I disconnect 'puter now, or too late?
Thanx!
Re: help me
Posted: Sat Sep 19, 2015 5:36 pm
by Earthbound
Should ok to unplug = but do not plug in again until print is finished. The USB enumeration that takes place upon connection would cause the RAMBo to reset, killing the print.
Re: help me
Posted: Sat Sep 19, 2015 5:38 pm
by GPriv
K
Thanx!
