Spiral fail
Posted: Fri Dec 19, 2014 3:20 pm
So I was trying to print DonaldLindsay's Mini High G Chanter, first attempt came out alright using my usual Cura settings, but not really usable, broken surface, etc.. The second OTH.
[img]http://i.imgur.com/ev7mOpq.png[/img]
I changed the Shell thickness from .5mm to 2mm since I'd had issues with infil breaking the surface. I think the problem was that heat was building up in the part faster than it could disapate and that caused warping which started before the first hole. After the first hole it just didn't bridge back over, it just started to spiral upwards like the flutes of a drill. Might be time to look into getting a layer fan.
This was a shame too, because for once the raft came off really easy.
