After much fussing with slicer settings and seemingly endless print attempts, came to the conclusion that one should no longer live in denial of the flickering lights as the heaters hit their setpoints, ever prolonging bed heating times, loss of hotend temp with the slightest puff from the part fans, not to mention the 11.6 input voltage level at no load, and accept that the filament starvation problems that would appear after the first 40 minutes or so from a cold start in the morning
were probably less likely associated with my ineptitude (usually the best place to start) in attempting to get PETG to go through a 0.3mm nozzle and possibly due to the glaring symptoms of a fading power supply. Scraped together the money for a 400W TPLE-12400N LED Driver power supply and...
INDEED IT WAS.
Looking at the tool paths, the starvation problems appeared to have originated at the start of a new layer. Interestingly, the extruder motor seems to now run much cooler (subjectively to the touch).
Time to Replace the ATX type Power Supply???
Jump to
- SeeMeCNC Announcments
- ↳ General Announcments
- ↳ SeeMeCNC crew in the wild
- ↳ 3D Printing Contests
- ↳ Development Topics
- General Forums
- ↳ New Member introduction
- ↳ The Lounge
- ↳ Live Stream Announcments
- ↳ Show us your machine!
- ↳ What are YOU making?
- ↳ General Tips 'N Tricks
- ↳ Troubleshooting
- ↳ Rostock MAX Official Docs
- ↳ ORION Official Docs
- ↳ GCode & Test Prints
- ↳ The Build Zone
- ↳ FAIL HAPPENS ! ! !
- ↳ Filament
- ↳ Test Forum
- ↳ Members Marketplace
- Regional Forums
- ↳ Sprechen Sie Deutsch
- ↳ Parlez-vous français
- ↳ Hablas español
- ↳ Australia and New Zealand
- Extrusion Based Machines
- ↳ Artemis
- ↳ BOSSdelta 300
- ↳ BOSSdelta 500
- ↳ RostockMAX v4
- ↳ RostockMAX v3.2
- ↳ RostockMAX v3
- ↳ ORION
- ↳ ERIS Delta
- ↳ Hacker Series - H2
- ↳ Rostock MAX v2
- ↳ Rostock MAX
- ↳ H-1.1 3D Printers
- ↳ H-1 3D Printers
- ↳ Other Machines
- ↳ RailCore
- ↳ Scorpius™
- ↳ Constellation
- UV Liquid Resin Printers
- ↳ DropLit
- ↳ Resin Materials
- ↳ Troubleshooting
- ↳ Development Ideas
- ↳ Skylight
- Hardware Store
- ↳ Nuts and Bolts
- ↳ Computer Hardware
- ↳ Mods and Upgrades
- ↳ Heated Bed How-To's
- Software
- ↳ AutoDesk 123D
- ↳ OpenSCAD
- ↳ Blender
- ↳ Sculptris
- ↳ SolidWorks
- ↳ FreeCAD
- ↳ Other
- ↳ OctoPrint
- ↳ Mach3 Software
- ↳ EMC2/LinuxCNC
- ↳ Slic3r
- ↳ Skeinforge
- ↳ KISSlicer
- ↳ Cura
- ↳ Repetier Host
- ↳ Simplify3D
- ↳ MatterControl
- ↳ Creation Workshop
- ↳ Fusion 360
- Electronics
- ↳ RAMBo
- ↳ RAMPS
- ↳ Azteeg X3 and X3 Pro
- ↳ Beaglebone Black
- ↳ Duet
- ↳ Sanguino (lulu etc...)
- ↳ Gen6 and variants
- ↳ Printrboard
- ↳ Power Supplies
- ↳ Alligator Board
- ↳ Other Controllers
- ↳ OTHER Electronics
- SeeMeEducate
- ↳ Teachers Lounge
- ↳ Show Your Work
- ↳ Software Help
- ↳ Design Help
- ↳ Show and Tell
- SeeMeFPV MultiRotor Forums
- ↳ General FPV topics
- ↳ Motors
- ↳ ESC's
