Parts to convert the Orion to Rostock ish size.
PopolZ
Post by PopolZ »
So I'm getting a bit limited by the size of the Orion. I was tempted to order a second printer but I'll keep my wallet happy and convert the Orion instead.
The parts list I need to order: the Rostock delta arms, laser cut sheets, glass plate, Onyx bed, 3x 48" of 1X1 T slot and GT2 belts.
I know I'll have to rewire a few things with longer wires.
Am I missing anything???
Orion Delta Printer
3 Axis CNC router + rotary axis
Craftex B2229 Lathe/Mill combo
Holy1
Re: Parts to convert the Orion to Rostock ish size.
Post by Holy1 »
I considered this also, it should work fine. However I considered the costs and time involved. You would have useless parts left over from the Orion in a box and a larger max. I decided to just to buy a new max. The build time would probably be comparable and much cleaner and I will have two printers. You can always sell the Orion too.
Orion to Cartesian viewtopic.php?f=59&t=7808
The V2 conversion kit would have most of what you need. I don't have the parts list in front of me, but I know it would get you awful close.
Have to order the larger Onyx bed at least.
PopolZ
Post by PopolZ »
The V2 conversion has quite a few parts I already have.
Orion Delta Printer
Fester
Post by Fester »
I will order the Max v2 soon :mrgreen: 2 printers.... Yeeee haaaa the only way to melt more plastic ... :lol: Now I just have to sell a few Rc planes ... :P
PopolZ
Post by PopolZ »
Well my printer upgrade money just went away in a lathe/mill combo machine :oops:
it's a bigger toy :mrgreen:
Orion Delta Printer
PopolZ wrote:Well my printer upgrade money just went away in a lathe/mill combo machine :oops:
That's next on my list. I'm thinking about a combo machine from Grizzly and then converting it to CNC with my recently acquired knowledge of it from 3D printing.
PopolZ
Post by PopolZ »
It ain't as easy as 3D printing. When you get to depth of cut, feed rate, rpm, width of cut, plunge rate, end mill changes + most likely a few things i'm forgetting are the difference between a succesful cut or a mill breaking and shooting across the room.
edit: oh and it's messy!
Orion Delta Printer
Correct you are. I'm semi-familiar with the intricacies of "real" machine work, and definitely understand that it's no walk in the park to automate, I just meant that I'm not scared of stepper motors and controller boards anymore. I'd probably start with something simple like auto-feed, and keep going from there.
PopolZ
Post by PopolZ »
Once your have you machine running and fully calibrated comes the fun part of getting a good cam software.
So much to choose from and so damn expensive :shock:
Orion Delta Printer
Post by Mac The Knife »
For the hobyy work I do with my small mill, (Sieg X2) I use Mach 3 to control it, and the cam software I use is Sheetcam, Meshcam and V-Carve. To simulate toolpaths, I bought Cutviewer Mill with Meshcam.
PopolZ
Post by PopolZ »
I also bought Meshcam and Cutviewer but they have big downsides when it comes to the 4th axis.
Orion Delta Printer
Sorry for jacking your thread, OP :)
PopolZ
Post by PopolZ »
It was my thread anyways... even if we're off-topic it's still interesting! :mrgreen:
The new beast in its crate...
Orion Delta Printer
Return to “ORION”
