Hi All,
So I got my Orion this morning, got it setup ad calibrated. Started printing a set of parts for a Kossel Mini (plate_3X) in ABS. Aside from the fan hitting the bowden/wiring while doing the skirt and a little curling on the bigger parts it was looking good. Then, just about 50% into the print, the Orion completely shutdown. LCD, hot end, bed, motors all off. I had to toggle the power switch to get it on again. So disappointed.
Not really sure what could cause this unless it's the power supply over heating. I've been building deltas since Johann first released the Rostock and have never seen this before. Any ideas or should I just send it back?
BTW: I was printing from SD.
regards,
aj
Brand New Orion Shutdown ~3hrs into print
Re: Brand New Orion Shutdown ~3hrs into print
I had a problem like yours. Here is a link to the thread.
http://forum.seemecnc.com/viewtopic.php?f=37&t=5958" onclick="window.open(this.href);return false;
You should also email seeme support. They will want to know your issues and give some quick answers
Thanks to you both.
I will be contacting support. For now, I've just removed the front panel and it's been printing fine, though I haven't tried the same plate again.
