Buckethead - Rostock Max V2 to V3
Posted: Wed Jan 04, 2017 3:02 am
Hey everyone.
Meet Buckethead, or Cakehat, or Cakefacehead or whatever. My V2 turned V3 + Mods:
[img]http://trash80.com/junkfood/rostockmax/1.jpg[/img]
[img]http://trash80.com/junkfood/rostockmax/3.jpg[/img]
The obvious first mod is the case. It's the slim case by Noircogi available at http://www.thingiverse.com/thing:1796438 out of 1/4in acrylic with a few minor tweaks. For the case door's latch I inserted a 1/4" magnet into the unoccupied screw hole and mounted a bit of metal onto the door:
Since the case does not fit the stock hotend part cooling fans I opted for blowers and a bit of my own design along with switching out the HE280 for my old V6 out of personal preference:
I upgraded the brains of the operation to the Duet Wifi and PanelDue with 7" display and thus needed a way to mount it so I added standoff holes to the top plate of the door side of the enclosure design:
To finish off the enclosure I added parts gutted from a tiny $20 space heater as well as a large PC fan to circulate the hot air back down: (you can see them mounted at the top)
It only needs to reach around 50C so the heater worked out fine and it already has a thermal cutoff fuse so the only bits required was to shove a thermistor 3/4 the way down the whip to track internal temp and adding a AC SSR into the top, all nicely controlled with the Duet controller.
Since both the top and bottom compartments are now completely blocked off (holes and all) from the heated chamber I needed new ventilation. I still had the RAMBO LCD case panel with the giant hole in it, so printed a copy of it and found some scrap metal mesh to make nice vents:
Because the bed took so long to heat up it was upgraded to a 24v (20v) supply via Noircogi's thread: http://forum.seemecnc.com/viewtopic.php?f=35&t=10904 I also added a thermal 100C cutoff fuse mounted to the backside of the heater PCB. (This might change but it's a good start)
I'm diving into nylon printing as well, and wanted a dust and moisture resistive spool container. I bought a cheap cake container on Amazon and put a large turntable in it. Added rubber sticker back feet to the turntable to grip to the spool and added a rubber grommet with the V2's old bowden tube to make the run to the extruder. (I already had the turntable from another project, it's a bit excessive otherwise)
I switched out the EZ Struder to the Bondtech QR because I was having a tough time with flexible filament. Thanks to mhackney for his blog post it made the transition easy. http://sublimelayers.blogspot.com/2016/ ... on-my.html
Finally the last mod I made, was the HE280's accelerometer i2c adapter for the Duet. http://forum.seemecnc.com/viewtopic.php?f=112&t=11267 I used a Teensy for fast development, and later mhackney also made one for the Trinket as well: http://forum.seemecnc.com/viewtopic.php?f=112&t=11286
Hopefully my mods are over for awhile. I am sick of tearing the poor thing apart every other week.
And for now I'm getting some pretty great prints. Thanks for sharing info on the forum guys! This community is pretty great even for lurkers like me.
Spoiler:
Spoiler:
Spoiler:
Spoiler:
Spoiler:
Spoiler:
Spoiler:
