Printing on a thin film held by vacuum
Posted: Fri Jan 27, 2017 2:17 pm
A vacuum to hold down a build stage offers the possibility of using very thin films to build prints on; this film can be sacrificial if cheap enough.
I have done some early trials with a vacuum table that I have fitted to my Delta printer and first tests have been very encouraging. I put a video on YouTube showing a rapid print change https://www.youtube.com/watch?v=cBisjaN8YK0
In this case the build surface was Laser Overhead Transparency film and the print material was PLA but this was not much good with ABS. An interesting result came with using the film from a Document Lamination Pouch, the inner surface is a kind of hot-melt glue and this prove an excellent surface on an unheated bed with PLA and even gave encouraging results with a warp prone print in ABS, again with an unheated bed.
The setup at present is overly complex although not quite as bad as it looks; a video of the bed vacuum and heater side of the build stage being machined in a re-purposed 3D printer can be seen at https://www.youtube.com/watch?v=Jz5oezLPVYU A recessed grove was cut on the same plate to put resistance wire in for the heater.
