No, that stuff is 15mm x 15mm, same as Openbeam. It's what the mini-kossel uses. You could make a max-sized machine from it, but it wouldn't be as stiff.Barefoothurst wrote:Check this out. I think it's the same but I haven't checked the exact specs.
http://us.misumi-ec.com/vona2/detail/110300465870/?rid1" onclick="window.open(this.href);return false;
The Rostock Max clearly uses a larger size, since it uses T-nuts, not sure exactly which. I don't own a Max to check.
