Repetier Randomly Crashing
Posted: Thu Aug 27, 2015 7:48 am
Hey there,
I am running repetier V0.92.4 on an Azteeg X3 Pro with a Viki2LCD on a homemade rostock printer. After one faulty board and a couple of days spent calibrating the machine, I have ran into a problem when repetier randomly crashes at different points in the print, and the whole machine resets.
I am using Simplify3d to slice the file and it is just a simple 20mm calibration cube. I have ran the print off the SD card with and with out a computer connected and ran it directly from simplify3d and repetier-host, and still the same issue crops up. I have attached the stl file and g-code of the failed print, if anyone wants to try it and confirm it is not the slicer and in fact the firmware? I have also been reading on other posts that you can create a log of a print to see where it is going wrong, which I think is the next step. However, I haven't figured out how to do this yet since I am rather new to all this.
Regards,
Euan
Regards,
Euan
