I made changes to the slic3r as per Rostock Max PDF ver. 1.45 feb 28, 2014. and save each tab then when I go to run Slic3r I get this error and do not know where the .gcode file is. no file in the specified user directory.
Repetier can not find file
- joecnc2006
Joe
Re: Repetier can not find file
I don't know if it will help or not but in Slic3r, Manager Tab, you can enter a configuration directory and putting a folder of your choice in there may help with your issue.
I am not 100% on this but it is worth a try.
