Cura 4.5 Profiles
Posted: Fri Feb 21, 2020 5:32 pm
by PartDaddy
Very happy with the performance of the new version of Cura 4.5 and we've been busy updating new github.com/seemecnc slicing profiles this week.
They fixed the single hotend multiple extruders in this release. Very happy with the performance too.
https://github.com/seemecnc/slicing-profiles
We categorize our slicing profiles by
hotend type, then slicer, then slicer version.
Re: Cura 4.5 Profiles
Posted: Sat Feb 22, 2020 10:46 am
\o/
Posted: Mon Jun 22, 2020 4:56 pm
by dajay23D
Thanks! Can you also update the END GCODES? I think something's off. I got a RTP V4 and whenever i use Cura, I get a large retraction when the print ends. It retracts to the point where it separates from the hot end. So i have to manually feed it back close enough where i can run the Load Filament Macros again.
Or i can just copy and paste the Cura Single Extrusion Guide end gcode.
Here's the current gcode in the V4 files.
T0 P0
M18 E1
G91
G1 Z0.3 F10000
G90
G92 E0
G1 E-3 F2000
G92 E0
G1 E-155 F5000 <---- i think that's the culprit! I haven't tried, yet.
G92 E0
M104 S0
M140 S0
M203 Z14000
G28
Posted: Tue Jun 23, 2020 8:32 am
The line you identified is there to back the filament out of the Y splitter on dual-extrusion machines. You can comment it out by sticking a ";" in front of it.
Posted: Mon Aug 03, 2020 7:49 pm
by Dankr
I have a rmax v2 with the e3d v6 hotend. Which would I choose?
Posted: Tue Aug 04, 2020 8:25 am
Any of the HE280 profiles should work for the E3D v6.
Posted: Fri Aug 07, 2020 6:26 pm
by Dankr
Thank you very much!
Posted: Sat Aug 08, 2020 10:42 am
You're welcome!
