Extruder motor on E1 instead E0
Posted: Mon Oct 03, 2016 6:00 pm
by iKeyborg
Hello all,
Which parameter in Rambo firmware configuration will change active extruder motor port from E0 to E1? without other changes?
(If it is possible).
Re: Extruder motor on E1 instead E0
Posted: Mon Oct 03, 2016 10:26 pm
by Eric
Look in "pins.h". Search for "301" to find the Rambo section:
#if MOTHERBOARD == 301
#define KNOWN_BOARD
* RAMBo Pin Assignments
scroll down to find
#define E0_STEP_PIN 34
#define E0_DIR_PIN 43
#define E0_ENABLE_PIN 26
#define E0_MS1_PIN 65
#define E0_MS2_PIN 66
#define E1_STEP_PIN 33
#define E1_DIR_PIN 42
#define E1_ENABLE_PIN 25
#define E1_MS1_PIN 63
#define E1_MS2_PIN 64
Change the labels to swap E0 and E1. Add a comment to remind yourself.
// E0 and E1 swapped!
#define E1_STEP_PIN 34
#define E1_DIR_PIN 43
#define E1_ENABLE_PIN 26
#define E1_MS1_PIN 65
#define E1_MS2_PIN 66
#define E0_STEP_PIN 33
#define E0_DIR_PIN 42
#define E0_ENABLE_PIN 25
#define E0_MS1_PIN 63
#define E0_MS2_PIN 64
