My intention is to get my Rostock Max v2 set up so I can utilize the Open DACT software on my machine. I realize that I will need to add a micro switch to the existing electronics of my machine. The trouble that I am having is locating a supplier that sells the connectors that plug into the Rambo board. I am sure that I am Googling the wrong questions. Will you help me locate someone that sells the connector that allows micro switches to be connected to the Rambo Controller. Please add the correct name for these connection so that I may know what to call them the future.
Thank you in advance.
Rambo End Stop Connector
- Prints-a-lot
Re: Rambo End Stop Connector
Dupont connectors are a good start. You can always use those with standard pitch headers.
Thank you for your help. I got to thinking that these connectors look similar to the ones used in the RC Model Airplane World (something I pretended to do in another life). I dug thru some of my old stuff and found some old servo connectors and extensions. I believe I will try this for now. What I would like to find is a connector that has the retaining mechanism. Anyone have a source for them?
Thank you.
Thank you.
See here: http://www.hansenhobbies.com/products/c ... in_lp_1x4/Pyropainter wrote:Thank you for your help. I got to thinking that these connectors look similar to the ones used in the RC Model Airplane World (something I pretended to do in another life). I dug thru some of my old stuff and found some old servo connectors and extensions. I believe I will try this for now. What I would like to find is a connector that has the retaining mechanism. Anyone have a source for them?
Thank you.
Thanks for your help, I will check them out.
