Need help with dual extruder
Posted: Mon Feb 09, 2015 1:55 pm
Another dual extruder question.
So I've been working with Bubbasnow's design regarding the dual extruder design.
http://www.thingiverse.com/thing:278076" onclick="window.open(this.href);return false;
I've put dial indicator inplace of the extruders to see if I can actually level this thing. I can get it in within a half a thou on all towers. So i know full well it can be leveled.
The problem is when i introduce the dual extruder design. After some work with shims I'm able to approximately level the nozzles.
The problem I'm running into is this.
Legend:
Red, Green Yellow, Blue are the positions of the nozzles
Orange refers to nozzle 1
Light Blue refers to nozzle 2
Assume Nozzle 1 and Nozzle 2 are offset by 1000 in the Y direction
So after much calibration I've run into an issue.
In red position, Nozzle 1 (orange) is pinning the paper, while Nozzle 2 (light blue) is high and just grabbing the paper.
In blue position, Nozzle 1 (orange) is just grabbing the paper, while Nozzle 2 (light blue) is pinning the paper.
In green position, Nozzle 1 (orange) and (light blue) are both about even.
In Yellow position both nozzles are even.
I have zero clue how to fix this.
If I shim to make up the difference at red position, its just going to tilt and make thins worse at blue position and offset what I have at green position.
If i adjust printer radius, it might help red, but because position blue and green are not perpendicular to the towers, l'll probably just make a huge mess of things.
It just doesn't make any sense. I'm using Tricklaser's Carbon Fiber arms and E3D V5 nozzles. I shouldn't have any arm issues. They should be all the same. My effector plate should be flat. otherwise i'd see a consistant nozzle 2 hitting the plate. Its like there's a bump between position red and blue.
Please help.
Legend:
Please help.
